jawor10 Erstellt 2. Dezember 2015 Erstellt 2. Dezember 2015 Hello, i got problem with dpf filter, carports says, that he is full in 29% and need to cleaning :) (ofcourse my car sayd the same) I got codding from vcds: Select] [01 - Engine] [Coding-II - 11] Enable Regeneration by Entering 21295. [Do It!] [Meas. Blocks - 08] Select both Groups at once 070 and 075. [Go!] MVB 070.1: Regeneration Status (xxxxxxx1 = Normal Regeneration active, xxxxxx1x = Forced Regeneration active) MVB 070.3: Regeneration Counter/Timer MVB 075.1: Exhaust Gas Temperature before Turbo Charger MVB 075.2: Exhaust Gas Temperature before Particle Filter MVB 075.3: Particle Filter Load MVB 075.4: Exhaust Gas Temperature after Particle Filter Now Start the Driving Cycle and keep watching the Measuring Blocks (2nd Person required). [Done, Go Back] [Close Controller, Go Back - 06] When i use it i go to: 01- engine Codding-II And than i write: 21295 Than its something like: done! And nothing hapens. Someone have done it on this software and can help me?? I dont know what im doing wrong, if someone can help that will be great. Sorry for my english.... Se yaa:) Zitieren
jawor10 Posted 5. Dezember 2015 Author Posted 5. Dezember 2015 The problem its solved. If any one have fault p2002 or P242F(Dpf Filter load value 30%) and 30% car power than u need to do : You will do everything while driving. -Drive with second person, 10 min on highway with normal speed let the engine to warm up ;] -In car ports take block 75 to see temperatur on normal drive u will see something like 300C degree -If ur car its warm, than in carports Codding-II And write: 21295, done! This let you to use 100% power of your car and will increase temperature. - Now take 4 gear, 120 km/h something like 3500rpm. Temperature 500-800c degree. Drive 10min -Then i was drive 200km/h with 6 gear, only to cool him a litle bit. 3 min.... -Then i repeat again 4 gear, 120 km/h, 3500rpm after such surgery should no longer display information about dpf now u need only to erase faults. This is just my idea, which work on my car(audi a4 B7 11/2007 2.0tdi 140ps), i was done it today cause that was annoying....and its work for me !!! :D Maybe i can help someone... cya ;] Zitieren
