Welche hast denn Probiert? 27971, 10016, 12233, 21295 ... :D Kommt auf Steuergerät (EDC 15/16/17) an und Motorisierung. Bei manchen Zeigt VCDS das passende an was in CODIERUNG 2 eingetragen werden muss.
engine
01283 Cruise Activation "older" vehicles
10002 Activate ACC
10016 DIESEL PARTICAL FILTER ADAPT
11463 ACCT CRUISE
12233 TDI SPECIAL
13647 ACT ADAP CRUISE
16167 DEACTIVATE CRUISE
21295 DIESEL PARTICAL FILTER ADAPT
45678 SPECIAL CUSTOMER SERVICE LOGIN
50000 AFTER RUN WATER PUMP ON
60000 AFTER RUN WATER PUMP
ABS
00212 MK60
01025 NDBW
04097 DBW
09399 SPECIAL A6
13204 FWD
13504 AWD
18446 AWD ESP
19469 MK60
23049 FWD ESP
27861 GEN ENABLE ADAPT
40168 Access to various basic settings
SUSPENSION
10273 TRANSPORT ACT
31564 LOGIN GENERAL ENABLE
41172 TRANSPORT DEACT
13861 Cluster, adaptation of the odometer can be carried out in Channel 9
20324 AIRBAG
12233 TDI login
EDC15/16
10000 Activation fuel cooling
10001 Deactivation fuel cooling
10008 Learning map FMA delete
10011 EGR is switched off next driving cycle
10012
10013
10014
10015
10016 DPF emergency regeneration V6, Common Rail
10019
10111 disable top speed limiter
11463 activate Cruise control
11971 Customer top speed limiter disable (Coding II) (top speed limiter adapt in adjustment 2 channel 14)
12233 Login EEProm get access to additional adaptation on diesel ECUs (4 cylinder MSA12 and newer for sure)
13265 Readinnes nachster Fahrzylus enable readiness setting mode on current (or next) driving cycle on some ECUs
13377
13647
16167 Cruise control Disable
16360
19676
20973 top speed limiter deactivation (AP18)
21295 DPF emergency regeneration 4 Cyl
22433 Deactivation AVS controller
22466 Activation AVS controller
22764 EGR is switched off next driving cycle 4 Cyl (Coding II)
27833
28575 Legal top speed limiter disable (AP07)
30579
30605 Teach differential pressure transmitter
31111
50904
22158 Access to adaptation channels with engine code AEL
26262 Access to adaptation channels in some ECUs
13647
EDC17
12233 Security Access code word for UDS
27971 Password for ShortTrip
ME7 Logins
07825
01283
11500 Default variant for variant coding
11223
11463
11501
12233
33162 Login for Development (1.8T go 1,2,3,4,5,6,8 channel, do not go channel 7,9,10,11,12)
34855
45678 Login for Customer Service (1.8T is accepted)
50000 Login Disable for hot country
60000 Login activate hot country
60301 Login for speed window 1 active (fan control)
60302 Login for speed window 2 active (fan control)
60303 Login for speed window 3 active (fan control)
